goat Posted January 2, 2014 Share Posted January 2, 2014 good day when l did the oil seals and timing belts on my 92 loyale about a year ago l mistakenly took the reservoir off the ps- pump and now it leaks alot l have replaced the o-ring and searched for a gasket to no avail any thoughts or clues thanks goat Link to comment Share on other sites More sharing options...
El Presidente Posted January 3, 2014 Share Posted January 3, 2014 I'd just get a new one from the Junkyard if you can't find the gasket. You could also make a gasket with some bulk gasket material(you can get it at the autoparts store, it comes in a sheet) or just take it back apart, clean it really well, and reasemble it with anaerobic sealant. Josh Link to comment Share on other sites More sharing options...
goat Posted January 5, 2014 Author Share Posted January 5, 2014 l was thinking along the same lines dont know what the gasket should or would look like (dont know what happened to it when l first took the tank off) is rtv an anarobic sealant (im thinking not...) thnaks goat Link to comment Share on other sites More sharing options...
