EA81 quad headlight high beam issue
1983 GL Wagon 4WD
Low beams work fine.
When i pull back on the stalk switch, all 4 lights illuminate as they should.
When i push forward, turning the high beams "on" - all 4 lights shut off.
Any hunches as to whats going on here?
Searched to no avail.
Thanks!
My best bet would be the headlight combo switch on your steering column has a short / ground issue. Maby even worn contacts?
I had a similar issue with my 86 Brat. I replaced the switch on the column and the problem stopped.
It may be wise to wait for a more experienced response.
I will try to locate a picture of said switch.
Edited by 81EA81
