Uberoo Posted January 4, 2014 Share Posted January 4, 2014 So I found a 84 subaru front clip that I can buy for $50 to get the front suspension bits.The thing is I have to pull the engine and transmission first before I can have it. I have pulled engines from EA81 vehicles and I have pulled transmission from EA81 vehicles, but never both at the same time.My question is what is the least labor intensive way to get both engine and transmission separated from front clip+suspension?The front clip is supported off the ground about 1.5-2ft. Link to comment Share on other sites More sharing options...
john in KY Posted January 4, 2014 Share Posted January 4, 2014 Could just drop the entire front suspension if it is anything like the EA82 models and just leave the engine/transmission in place. Link to comment Share on other sites More sharing options...
scoobiedubie Posted January 4, 2014 Share Posted January 4, 2014 On the GL-Loyale series, the engine is not connected to the suspension. The engine is connected to the frame. The transmission is also connected to the frame. And the suspension is connected to the frame. All using difference connection points. You lift the engine out and drop the transmission, unless you really want to make things difficult. Link to comment Share on other sites More sharing options...
Gloyale Posted January 4, 2014 Share Posted January 4, 2014 If you have a good leveler on the hoist you can pull all as one unit. Unbolt and drop the crossmember down a bit first will help. Link to comment Share on other sites More sharing options...
jono Posted January 4, 2014 Share Posted January 4, 2014 (edited) what is there ...two bolts either side of the gearbox cross member, two nuts each side for the engine crossmember if they don't break first, and three strut top bolts and it should all fall to the ground in a hurry which is where a decent trolley jack comes in handy to drag it out once lowered. Before doing that I'd be undoing the front hub nuts 36mm and cracking tie rod tapers, remove engine mount nuts. But why pull their engine at all, suspend the engine from a coupla bits of decent lumber or steel across the top of the fenders or just insiode so no panel damage and leave their shuff hanging - take yer stuff and thank them Edited January 4, 2014 by jono 1 Link to comment Share on other sites More sharing options...
