Digital dash fuel gauge
I just finished the ej swap in my car to the point where it's on the road, the temp gauge I've just put in an aftermarket, but the fuel gauge is much more important. I know the gauge was working prior to finishing the swap. I've checked the resistance at the sender and it seems proper, I've replaced the connection at the sender because of corrosion, and at the corner of the trunk, from there the wires change color and I loose them. Does anyone know locations of the sender wire either at the glove box connections, or at the gauge itself? I've searched and can't find a pin out, and don't have access to the fsm. Any help would be appreciated, thanks a lot.
Edited by Turboturd
I'm not sure of the different years but the factory info I am working with is for the model year 1988. You should be able to find those wire colors going to the cluster and gauge. I assume the wire colors are the same for your model year but I can't say that for sure.
