old sub freak Posted January 7, 2014 Share Posted January 7, 2014 Hey Gang,I have a 83 Brat with a Hitachi carb and 150,000 miles. So all has been well till a month ago it started to have a high idle once it warmed up,like 2,200 RPM's. I cleaned and oiled all the linkage and that helped some.It now goes between 600 RPM's and 2,200 RPM's. More than once after going 10 miles it will drop to 6 or 700 at a stop.Today I drove it 3 miles to the store..High idle ,drove back home still high.I opened the hood and tryed to manualy turn the throttle back but no go.something is holding it high..the cable has play in it so that should be ok,must be linkage related..any thoughts? thanks ,Todd Link to comment Share on other sites More sharing options...
millhouse Posted January 7, 2014 Share Posted January 7, 2014 My 85 had the same issues. Sounds like its about time for a weber carb swap. Link to comment Share on other sites More sharing options...
RustyBrat Posted January 7, 2014 Share Posted January 7, 2014 weber carb is definitely the way to go, however if you are dead set on keeping your hitachi... it really sounds like you are having vaccuum problems. just go along every hose with your eyes and look for cracks or dry rot. Link to comment Share on other sites More sharing options...
ferox Posted January 7, 2014 Share Posted January 7, 2014 Sounds like a classic vacuum leak. Link to comment Share on other sites More sharing options...
old sub freak Posted January 7, 2014 Author Share Posted January 7, 2014 Cool.... I'll look into that and let u know,Thanks Todd I Link to comment Share on other sites More sharing options...
millhouse Posted January 8, 2014 Share Posted January 8, 2014 my vac leaks were internal with the carb, I purchased a rebuild kit from o'rileys for like 25 bucks. replaced the gaskets, accelerator pump, check ball etc.. i was still having vac leaks so I used a cigar (while car is not running) and blew smoke into the intake and you could see where the leaks are. i had to chief down and entire cigar but don't give up! they will appear… i promise. the other classic vac leak is where is EGR connects. After dealing with this for a few weeks, I decided to go with the weber. If you have any questions about the weber just let me know. I can show you the exact parts to get to complete the installation. Link to comment Share on other sites More sharing options...
old sub freak Posted January 9, 2014 Author Share Posted January 9, 2014 I may go that route but for now....I have a vacuume guage on my dash and it reads the same, 22 weather it was idleing at 700 RPM's or 2,200 RPM's and i can't turn the idle down by turning the throttle back.Its solid,so I'm thinking the linkage is jammed somewhere. I need to take off the air cleaner and see what could be holding it back...hey thanks for the info...I'll be back.... Link to comment Share on other sites More sharing options...
naru Posted January 9, 2014 Share Posted January 9, 2014 Sounds like the fast idle cam is hanging up. Confirm that the fast idle screw does not touch the cam behind the choke thermostat after the choke opens. Not unusual for the cams to gum up and stick. I would also check that the secondary throttle is not hanging open. Link to comment Share on other sites More sharing options...
Dwayne Oxford Posted January 9, 2014 Share Posted January 9, 2014 I had to put a spring behind carb to pull secondary closed. I'll take pic if you need. Link to comment Share on other sites More sharing options...
old sub freak Posted January 9, 2014 Author Share Posted January 9, 2014 That would be great. I have never been to hot on these "New Fangled Carberators"..Other than RxR..I know webers and old school one barrels.... so yea any pictures would be cool,thanks,Todd Link to comment Share on other sites More sharing options...
old sub freak Posted January 15, 2014 Author Share Posted January 15, 2014 Well to all you folks loosing sleep thinking about my wierd carberator problems..... You can sleep tonight..after checking this and that it turned out that the butterfly valve is loose in the carb, I was checking for leaks with carb cleaner and I sprayed some on the side of it and Bingo..started to stumble. I tried to rock it up n down and sure enough it had freeplay... so unless i can find a new hatachi for $250 bucks I guess i'll be doing a weber soon. Thanks again for all the imput,Todd Link to comment Share on other sites More sharing options...
RustyBrat Posted January 15, 2014 Share Posted January 15, 2014 glad you figured it out! weber all the way! so much easier and simpler that way Link to comment Share on other sites More sharing options...
old sub freak Posted January 19, 2014 Author Share Posted January 19, 2014 Hey Naru... You were right .I thought the slop in the butterfly valve was causing the fast idle. No...It was the linkage behind the choke housing.....Cleaned it good and light oil and Bingo....all is well. and once again..Thanks to all,todd 1 Link to comment Share on other sites More sharing options...
rrgrr Posted January 20, 2014 Share Posted January 20, 2014 On 1/9/2014 at 12:57 AM, Dwayne Oxford said: I had to put a spring behind carb to pull secondary closed. I'll take pic if you need. I would like to see that pic, having similar issues, weber is standing by waiting for me to give up... Link to comment Share on other sites More sharing options...
