johnceggleston Posted January 8, 2014 Share Posted January 8, 2014 (edited) i found this on legacyGT.com for a 99 outback key fob. (alpine 99 - 04) i would probably add a little WD40 to the drying process. it can't hurt. HTH This repair applies to the key fobs supplied for the Alpine securitysystem used in Outbacks and Legacys from 1999 to 2004, but I'm postinghere because ours is a 99. It may work on non Alpine fobs. It may notwork on your Alpine fobs. But it's something to try on a fob that mayotherwise need to be discarded. I found a third fob that only functioned whenit wanted, so I decided to do the same repair/de-corroding as describedabove. Except this time I took pictures.1. Take the fob completely apart. You'll need a jewelers sizedPhillips to remove the three small screws that hold in the circuitboard.Make absolutely sure that you remove the battery. If you use thisde-corrosion method with a battery installed you will actually makecorrosion, and could eat away and possibly destroy the smallerelectrical conductors.Of the three fobs I've de-corroded one had corrosion on the pins of both ICs on the back of the board.Two of the fobs had corrosion inside of the push button switches on thefront of the circuit board. The switches are the two identical squaremetal items mounted at a 45 degree angle with a round "button" in thecenter.I used Lime Away as a readily available acid that is also fairly safe.Even so I made my acid solution by diluting it about 50/50 with warm tapwater.Next I placed the circuit board in a small glass dish of the acidsolution and watched for a reaction with the corrosion, which is astream of fine bubbles. This board had no corrosion to speak of on theback, but the following picture shows the front with bubbles coming outof the push button switches and a bit of foamy froth floating on the topof the acid solution.Because the acid is consumed by the corrosion as it is eliminated youhave to agitate the solution every 5-10 minutes or so. This is to makesure there is fresh acid at the site of the corrosion. I used my indexfinger to shake the circuit board for about 5 seconds, with a quick tapwater rinse after the agitation. (Rinse the finger, not the circuitboard.)I soak the circuit boards until the foaming stops, which was about 20 minutes for this particular circuit board.After the acid I soak the board in warm tap water to wash out anyremaining acid. I soak for at least 60 minutes and agitate every 10-15minutes. (I don't use a base, like baking soda, to neutralize the acidbecause the base and acid reaction will form a salt. I'd rather uselots of water to flush the acid out and sidestep the hole issue ofneeding to wash out some kind of salt.)Next step is drying. I used canned air to blow the obvious moistureaway, followed by air drying for a couple of hours in a warm, dry place.If you don't have canned air then shake it off and leave it overnightin a warm dry spot.When dry just put the thing back together. Cross your fingers and see if your fob works again. Edited January 8, 2014 by johnceggleston 1 Link to comment Share on other sites More sharing options...
