lcb Posted January 10, 2014 Share Posted January 10, 2014 My passenger side blade works fine, drivers side moves a little, goes up just a little bit. 2003 Subaru legacy AWD Link to comment Share on other sites More sharing options...
lmdew Posted January 10, 2014 Share Posted January 10, 2014 The nylon bushings on the rods that connect the wipers go out. Pull the wiper arms Pull the plastic cover that goes across the bottom of the windshield and under the hood You will see the linkage and rods. You have to buy the complete rod as I have not found replacement bushings. Dealer or Junk yard. Link to comment Share on other sites More sharing options...
Suzam Posted January 10, 2014 Share Posted January 10, 2014 It also might be as simple as snugging down the nut under the rubber plug on the bottom of the arm. The parts are made of softer metal and will "strip" a little if the blade has been frozen or pushed heavy snow on the windshield. 1 Link to comment Share on other sites More sharing options...
lcb Posted January 11, 2014 Author Share Posted January 11, 2014 Thanks, it was simply the bolt had come loose. Easy and free to fix. 1 Link to comment Share on other sites More sharing options...
