Oil Consumption fill the oil and check the gas 2000 2.5 SOHC
154K on the motor.  Previous owner had bent all 8 intake valves so I replace the valves and head gaskets.
Runs great but using oil like mad.  No external leaks, no smoke to speak of.
Ran it 300 miles yesterday at 75 or so, down almost 3 quarts.
PVC is valve is good
Ran Seafoam in the oil for about 30 miles and then changed the oil before my 300 mile trip.
Replace the PCV if its old, even if it rattles the valve mechanism can still be bad.
If the oil changes were neglected at some point in the past the oil control rings may be seized, and could take some time to free up. Might try running some MMO in it and drive it easy for an hour or so, then change the oil again.
Backed it into the garage today and got on the throttle pretty good.   Yes it smokes.
Replaced the PVC valve and I'm running some MMO with the oil to see if it frees up the rings.
Might be a rebuild.
Hard to  believe it runs so well.  It's like I'm driving the old Caravan with the 3.0 smoker in it again.
Thanks Larry
  • 1 month later...
Back to this project:
New Subaru PCV installed.  It decreased consumption some but not much.  Still using over a qt for every tank 300 miles.
Ran MM Oil in the engine trying to free up any possible stuck rings
Plugs very black and oily,
Cylinder             Compression               Leakdown
1                         135                             100/96 = 4%
2                         140                             100/97 = 3%
3                         140                             100/97 = 3%
4                         135                             100/96 = 4%
The leakage was heard in the oil fill, so it's going past the rings but I don't think it's excessive.  For the Compression reading, remember I'm at 6300 ft here in Colorado so the numbers are lower than what you'd see at sea level.
Once my Oil Pan Oring seal gets here I'm going to drop the pan and inspect that seal.  If it's not that seal, what else could it be?
The engine runs great, Head Gaskets just completed.  No external leaks.  New Subaru PCV.
have you checked the oil pressure? just wondering if a stuck relief valve could cause high usage?
I once read of someone that had the PCV and breather hoses all cross-connected and they had weird issues with oil.
just wild guesses since you seemed open to them!
If the PCV hoses were plugged wouldn't there be a vacuum in the crankcase...so you could put a vacuum gauge on the dipstick tube or the oil filler tube and see a vacuum on the gauge?
  • 5 weeks later...
Gunk Engine Cleaner helped, as I ran the engine with it in the oil I could hear the change.  The oil consumption is down but still high, a quart of more every tank, 300 miles.
I can get the engine to smoke out the tail pipe if I rev the engine numerous times quickly Idle to 4000 RPM and back.  Steady RPM it's no smoke.
Review of items done and the engine:
154K 2.5 SHOC 2000 - Had bent intake valve, so I surfaced the head, glass plate and replaced and lapped all the valves.  Engine runs great.
- New Subaru PCV
- All hosed clean and connected properly
- Seafoam in the gas and Oil
- MMO in the oil
- Leak down check, see numbers above
- Gunk Engine cleaner, seemed to help but did no solve the problem
- No external leaks
- Runs Great
Pretty much down to stuck Oil control rings, engine pull.
Thoughts?
Did you ever remove the oil pan?
There is a ring seal on the pan for a tube that connects to the bottom of the separator chamber. If the seal is broken or gone it apparently causes high oil consumption.
High vacuum in the intake can pull oil past worn intake valve stem seals. Usually this is noticeable if you coast down a long hill in low gear that keeps the engine speed up and intake vacuum high for a prolonged period.
Did you replace the stem seals when you did the valves?
Sad to say, I have not gotten to the Pan, nor did I replace the valve stem seals.
I know I could do both with the engine in the car but might just be easier to pull it.
It will go to the sideline for a month or so, got 6 other ones that I'm working on and lots of travel for work.
Thanks for the feedback!
Larry
I'd have to call it stem seals.
Keep 1/4 - 1/2 quart of MMO in it. The oil control rings lands in the pistons have drain holes that do have a tendency to plug up with infrequent oil changes, then the rings get stuck. MMO or a high mileage motor oil may clean them out. Neither one will hurt so its worth a shot.
  • 2 years later...
Changed the Oil Pan return tube o-ring seal and the Valve Guide Seals.
Some said it could not be done and I would not opt to do it again, but I was able to change the valve guide seals without pulling the heads.
Installed the Timing belt so I could rotate the cams until there was no tension on the valves.
Removed both sets of Rocker Arms
Removed the Plugs
Put the piston at BDC and put rope down the plug hole to fill they cylinder
Rotated the crank to bring the piston up to compress the rope and hold the valve up
Used a valve spring removal tool, the one that catches the keepers to remove the valve springs
Used a Plug Wire Pliers to remove the old valve guide seals
Installed and seated new valve guide seals
Now the hard part, compressing the springs and getting the keepers in:
I used a tool sold for this purpose, but it was too large for the Subaru Valves.  I turned down the pin on the lathe.
It worked about 50% of the time.  When it didn't work, one Keeper was in the other was out.
The last time I did valve with the heads off, I had made a valve spring compressor out of PVC Pipe.
A 1 1/2 Tee with a 3/4" piece of PVC about 8" long works well.  You can cut a 1/2" notch out of the end that will allow you to insert the keeper while you compress the spring.
Motor in on my next free day, I hope this has solved the oil consumption issue.
Larry
Sunday, I installed the motor.  It started and ran great for about 20 minutes, and then started knocking, sounded like a rod knock.  Shut it off, it was the end of the day.  Strange it ran just like a Subaru should for 20 min.  I had pulled the coil plug and cranked it to get oil through the engine before starting it and then when I did hook the coil up it started and ran great.
Monday - Thinking one of the valve keepers may have come off, I  pulled the fans, accessory belts and valve covers so I could check the valve keepers and crank it over by hand.
- all valve keepers and valve train looked good
- I pulled the plugs and turned it over by hand.  About every 2 or 3 turn as #1 came up on compression the crank would lock up.  I did not force it but it would not turn in the normal rotation with light pressure on my 1/2" ratchet.  I'd back up the crank a 1/4 turn and then it would crank right through a couple more rotations of the crank.
- Just putting my thumb in the plug tube, all cylinder have compression.  When I put the plugs back in, one at a time compression felt good as I turned the engine over.
- Everything back together and it's turning over fine, not locking up
- I get it pointed out the back of work to drive it to the parking lot.
- I start it, it's knocking
- A minute or so later, the knock turns into what sounds like valve tick
- Another couple of minutes and the tick is gone, it's running fine.
- Park it for the night
Any ideas what could have caused the Knock, locked up crank when turned by hand and then it goes away?
Very strange.
Thanks, Larry
Lifters get air in them and collapse and they'll knock louder than a sonuvawitch for a little while then clear up as the air pumps out and they fill back up. Not sure why the crank would be locking up unless maybe there was a chunk of carbon or something in one of the cylinders.
  • Like 1
Larry
Ah, valve stem seals was what first came to mind.  I'd bet they're hard and worn out and possibly now crooked because you had to replace valves.
Emily
