teppichkopf Posted April 29, 2004 Share Posted April 29, 2004 Anybody ever use replaceable CV boots? I've seen them at the parts store for $15 or so. These are the ones they do not require the axle being removed. They are one piece and secured with several screws. -cl Link to comment Share on other sites More sharing options...
rugbyben Posted April 29, 2004 Share Posted April 29, 2004 I have used then on a Honda. there call split boots right? theyre okay, a super easy intall but they obviously have to be looked after and dont last as long. But much cheaper then getting the OEM job done. Link to comment Share on other sites More sharing options...
northguy Posted April 29, 2004 Share Posted April 29, 2004 What outlet are they offered at? I have a torn boot and would try one of these out until I need to replace the axle if I had one available. Link to comment Share on other sites More sharing options...
teppichkopf Posted April 29, 2004 Author Share Posted April 29, 2004 I found them at the local parts store (a few years back). Don't know if they're available online. One of my boots is showing wear so I'm just planning ahead. Split boots sounds like the correct name. A quick search turned up this website http://www.raxles.com/spitboot.htm They don't recommend them. Looks like I'll just wait to replace the axle when the time comes. -cl Link to comment Share on other sites More sharing options...
intrigueing Posted April 29, 2004 Share Posted April 29, 2004 I used one that glued together once you had it in place, complete POS. I would have been better off using duct tape on the ripped boot. Link to comment Share on other sites More sharing options...
edrach Posted April 30, 2004 Share Posted April 30, 2004 I used them twice and certainly don't recommend them for a permanent fix; what northguy wants as a temporary fix is probably the right idea. I found them not to last 10K miles. Also, cleaning the old joint of the old grease and adding the new grease is a messy, ugly job. Then putting on the fine-pitch nuts on the overly long screws is a real pain also. But the kits have their use if you're willing to put up with the aggravation. I think I bought them from B&B (local chain) or NAPA--can't remember which. Link to comment Share on other sites More sharing options...
northguy Posted April 30, 2004 Share Posted April 30, 2004 Thanks Ed. I was told of the boot problem last Fall and drove it all winter -and so far no problems - but with Spring (mud, gravel, wet, more mud, off-road use...) I'd better put something over it so the axle lasts as long as possible. It's not clacking yet, but left unattended, it'll surely go downhill in a hurry. Link to comment Share on other sites More sharing options...
Tiny Clark Posted April 30, 2004 Share Posted April 30, 2004 Geeze, you probably still have ice in the CV boot from driving the Glenn Hwy. Even without mud, the grease has probably pretty much been washed out of the joint (no - not the kind of joint you get in Wasilla). With all the nasty stuff on the streets during breakup, I'm surprised it isn't grinding. I would put a new CV on with a new boot!! No sense in doing the same job twice. Link to comment Share on other sites More sharing options...
northguy Posted April 30, 2004 Share Posted April 30, 2004 I just didn't want to put a new axle in before I had to. A 2 piece boot would probably do for the time being, until I experience mechanical failure notification. Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted May 4, 2004 Share Posted May 4, 2004 i, personally, wouldn't want to put on a cheap, screw on, cv boot. the axle on my legacy isn't that hard to take out anyway Link to comment Share on other sites More sharing options...
