2011 Forsester Winter Wiperblades
Is there a trick to removing these wiper blade assembly?
I usually depress a tab and pull the arm off the hook.
There is no tab. There is large plastic piece surrounding the arm inside and out.
Totally stumped on this one.
I was considering just replacing the rubber part but do they even still sell them?
I bought a pair of Anco winter blade assemblies with the rubber than covers the entire arm but I would return them and just do the refills of the rubber part if that makes more sense.
Any help would be greatly appreciated.
lift the wiper arm up and look at the underside of the attachment part - there may be a small tab underneath that you will need to pull outward to release the wiper assembly.
it may take a little bit of wiggling the assembly to get it loose. When I replaced mine recently, I had to pull the whole assembly upwards to get the tab to release, then I could push down to get it off the arm...
