idosubaru Posted January 14, 2014 Share Posted January 14, 2014 i got this transmission from a wrecked car in which the transmission pan was dented. It did work and drive poorly after the accident. It's for a 2002 VDC H6. Two of the solenoids under the transmission pan have completely cracked where the electrical wiring harness plugs into them. if the solenoids are impacted - is there any other possible damage or probably just the whimpy connectors? the connectors are part of the solenoid so it looks as simple as install some new (used that i already have) solenoids with good connectors and off we go. but i'm unfamiliar with what those solenoids do and if there's any other possible repercussions. i'll probably swap the wiring harness as well (looks easy) and the internal screen filter which also looks like it may have been lightly touched too. Link to comment Share on other sites More sharing options...
CNY_Dave Posted January 14, 2014 Share Posted January 14, 2014 I would say the chances are good the valve body is OK. If you can pull the solenoids and give it a good visual inspection I'd say you can be sure. Bigegst concern might be if you pull a solenoid and you see it may have loosed chunks into the valve body. Not likely, but something to check for. Link to comment Share on other sites More sharing options...
ivans imports Posted January 14, 2014 Share Posted January 14, 2014 I recommend to replace orings on the replacement soiliniods and should be good to go Link to comment Share on other sites More sharing options...
idosubaru Posted January 14, 2014 Author Share Posted January 14, 2014 (edited) I recommend to replace orings on the replacement soiliniods and should be good to go thanks, will do, getting part numbers Solenoid Orings: Lock up duty (blue)806920040 Low clutch timing solenoid (gray)806908130 Line pressure duty solenoid(Red) - Oring #1 806920040 Line pressure duty solenoid(Red) - Oring #2 806904030 D)Shift solenoid 2 (Yellow) 806908130 (E) Shift solenoid 1 (Green)806908130 (F) 2-4 brake timing solenoid (Black)806908130 (G) 2-4 brake duty solenoid (Red) Oring #1 806920040 (G) 2-4 brake duty solenoid (Red) Oring #2 806904030 ATF temperature sensor isn't shown on opposed forces. If you're replacing all the solenoid orings it is: (4) 806908130 (3) 806920040 (2) 806904030 There are 3 external sensor orings: 806913070 Wiring harness oring: 806912140 This looks fairly generic for all 00-04 automatic transmissions Edited January 14, 2014 by grossgary Link to comment Share on other sites More sharing options...
idosubaru Posted January 14, 2014 Author Share Posted January 14, 2014 VDC and 4EAT transmissions (not front diff and rear extension housing) appear identical....maybe there's really not much difference bewteen VDC and 4EAT transmissions? Link to comment Share on other sites More sharing options...
CNY_Dave Posted January 14, 2014 Share Posted January 14, 2014 Is the VDC front diff different? Thought it was the same. I am pretty sure 4EAT non-VDC and 4eat VDC are identical except for the rear housing and the VTD center diff with VDC instead of the mpt. All the magic is in the TCU and the center diff. Link to comment Share on other sites More sharing options...
idosubaru Posted January 15, 2014 Author Share Posted January 15, 2014 Is the VDC front diff different? Thought it was the same. yes - but the final drive ratios are different, 4.11 for VDC and 4.44 for Outbacks. i looked it up on opposed forces and i think some impreza's share that 4.11 front ring and pinion set. so what this means is that by swapping a front diff and rear extension housing one can use any 4EAT transmission in a VDC? that's comforting since the VDC's are so hard to find and expensive. Link to comment Share on other sites More sharing options...
CNY_Dave Posted January 16, 2014 Share Posted January 16, 2014 Oh, that's why I didn't catch it- I was thinking vdc/non-vdc 4eats that were mated to an H6, all the H6 outbacks that gen have the 4.11s. Link to comment Share on other sites More sharing options...
idosubaru Posted January 16, 2014 Author Share Posted January 16, 2014 Oh, that's why I didn't catch it- I was thinking vdc/non-vdc 4eats that were mated to an H6, all the H6 outbacks that gen have the 4.11s. my bad, i was forgetting the non-VDC H6's in my comment even though i own one of those too. LOL so my H6 VDC and H6 non-VDC vehicles have interchangeable transmissions..minus the rear extension housing. fascinating. when i replaced the transmission in my 2003 non-VDC H6 a few years ago i think folks were saying VDC and non-VDC were not interchangeable. Link to comment Share on other sites More sharing options...
CNY_Dave Posted January 16, 2014 Share Posted January 16, 2014 The TCU and much of the car harness are different for VDC. You can put a VDC trans or just the rear bits into a non-VDC car, you just need to control the lockup clutch manually. The mpt in the vdc trans is designed to be locked or free, not to be partially slipping. It is the same size in diameter as the non-vdc MPT but has fewer plates. Link to comment Share on other sites More sharing options...
