Q's about lowering EA82 the factory way
XT front struts/springs will bring it down aeounds 2 inches...the rear springs is what you want, as the XT struts for the rear will actually raise you up. The springs will bring it down 1/2 to 1 inch.
Ok, now the question I really want answered. What will these to the front of an EA81? I know RX springs will raise the front about 1", so the XT springs will take away that one inch, then lower it 3/4 of an inch below the stock height? Probably the net gain on my car will be less because it is on a turbo wagon and they're lower already. Would I be able to use EA82 struts on my EA81?
  • 3 years later...
eureka
xt springs on 4wd wagon struts will lower it 1 inch is this what im hearing.
Ben
  • 4 months later...
  carfreak85 said:
XT springs WILL lower your EA82, but by how much, I'm not sure.
well i just found this out so bear with me. the xt6 springs and struts will lower about 2 inches but its the rear where it gets confuseing. I know flip the top hats but i didnt hear about useing xt rear springs. Which strut would you use then for the back.
Ben
