9945 Posted January 19, 2014 Share Posted January 19, 2014 Have an 88 Loyale 4wd wagon....needs a rear drive shaft.....can't find one anywhere.....or, a place to have this one rebuilt.....maybe, someone can help me out. I live in S Cent Pa. Quote Link to comment Share on other sites More sharing options...
djellum Posted January 20, 2014 Share Posted January 20, 2014 you can try a junk yard. any loyale wagon with the same trans should fit. find a local driveline shop, or machine shop and they can probably build you a 1 piece for around $100. theres a lot on these drivelines that aren't supposed to be repairable so replacement is the easiest option. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted January 21, 2014 Share Posted January 21, 2014 The rear part of the 2 piece driveshaft is the same between automatic and manual trans for 85-89 GL, DL, RX, 90-94 Loyale, and 85-92 XT. The u-joints are staked in, a toyota part number is compatible. Anyone experienced with toyota or nissan driveshafts should be able to do the work. Quote Link to comment Share on other sites More sharing options...
apintonut Posted January 21, 2014 Share Posted January 21, 2014 The rear part of the 2 piece driveshaft is the same between automatic and manual trans for 85-89 GL, DL, RX, 90-94 Loyale, and 85-92 XT. The u-joints are staked in, a toyota part number is compatible. Anyone experienced with toyota or nissan driveshafts should be able to do the work. Any idea of the part # or what nissan or toyota to look for to get the ujoint Quote Link to comment Share on other sites More sharing options...
