Has anyone had this happen before (crank sensor)
So I was cranking my new installed motor first without plugs or injectors, then I added them both and it still did not want to start.. so I said hmm, so I go and make sure my connections were good and I noticed the damn connector that plugs to the crank sensor the wires snapped right off of it!
Has this happened to anyone else?
I want to splice on another connector ( have a spare manifold here) but I need to know the correct pinout
reading around it seems like I'm not the only one this happened to..
it seems between 95 and 97 they still used the same wire color which is white and blue.. in the case of the wires it's a solid blue and a white striped blue wire
Edited by 1-3-2-4
