First time Subaru owner
You bought probably the best example of a subaru in terms of overall refinement with simplicity. The outback for 96 has the nefarious ej25d, but the 96 should have a composit head gasket instead of the metal layer gaskets that are prone to head gasket issues.
Should you have engine trouble (interference timing belt) you can easily swap in a 2.2 from a regular legacy 95-97, and have the option to build 2.2 heads on the 2.5 block for performance gains.
The car is not any less reliable than a newer model given the maintenance is kept up.
It was an awesome drive :) I've wanted one since college, but they are in high demand here - snowy winters, FINALLY I got one.  Very excited. Little electrical problem discovered at the grocery store, will get onto fixing it ASAP. Fortunately I have another vehicle I can drive in the meantime. She is very pretty, no?
You can't see it in the photos but there is a bit of rust right above where the metal body meets the plastic bumper. Not any more than my '05 Taurus. These are really good cars aren't they? I was torn between a Subaru Outback and a Jeep Cherokee. Well, we have a Jeep Cherokee and I honestly am not crazy about the stiff suspension, so I started looking for Outbacks. People think I'm nuts for buying an 18 year old car, but what can I say?
Now I'm just worried about getting the timing belt and all that goes with it replaced. I don't think I can do it myself and from what I'm calculating it'd be somewhere around what I paid for the car to get it done at the dealership.
I know I need to, asap since i have no idea when it was done last.
My problem is that I love to take things apart. It's the putting back together that gets me.
Where do you live?  Someone might be able to suggest a good mechanic your area.
somewhere around South Bend, In. There's a dealership, a few Import Specialists. Every Mechanic around here list Subaru as a car they work on. Which is fine, but 'work on' and 'really know their stuff' are two different things. I do have a coupon for basic maint (oil change, etc) that includes  a multipoint inspection for $54 at the dealership. Thinking I could take advantage of that and then get an even longer list of things I need to do. I had a very basic check done just to make sure there were not any big obvious issues. A dealer should be able to tell me if the timing belt, pulleys, idler and water pump had been replaced recetly...maybe...
good score man you'll love it! I just got mine running again as of Sunday and am stoked to be driving it again. and doing the timing belt isn't hard, if u can do basic maintenance than u should be able to handle that. pick up a Haynes manual for guidance, it will tell u how to line it up, route it and will even give u a tooth count to each pulley. I just did this Saturday. hope to see some mods on yours in the future.
