eword Posted January 23, 2014 Share Posted January 23, 2014 i recently purchased a 97 legacy outback for my daughter and discovered the radiator fan doesn't turn on. in stop and go trafic it will get close to over heating. but in the morning it takes forever to warm up. i expect to replace/ install a thermostat, but where is the fan relay? i should see why the fan does not turn on. right? check relay, then sensor? and isn't there 2 coolant temp sensors? it runs great and gets decent gas milage... thanks Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 23, 2014 Share Posted January 23, 2014 (edited) that's an EJ25D which is notorious for awful headgasket issues. my first thought it someone dumped it when they saw the issues and you bought it. but let's hope i'm wrong: 1. get the fans working 2. use a Subaru only thermostat (aftermarkets are notoriously whimpy, even visually, just look at them) 3. make sure it's properly burped - any air in the system and it will overheat. keep adding/filling nose up in the air. but if you're bubbling in the overflow tank - that's exhaust gases getting pushed into the coolant and you have a blown headgasket. very common for that engine and wouldn't surprise me if it was sold for that reason. Edited January 23, 2014 by grossgary Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted January 23, 2014 Share Posted January 23, 2014 that's an EJ25D which is notorious for awful headgasket issues. my first thought it someone dumped it when they saw the issues and you bought it. but let's hope i'm wrong: 1. get the fans working 2. use a Subaru only thermostat (aftermarkets are notoriously whimpy, even visually, just look at them) 3. make sure it's properly burped - any air in the system and it will overheat. keep adding/filling nose up in the air. but if you're bubbling in the overflow tank - that's exhaust gases getting pushed into the coolant and you have a blown headgasket. very common for that engine and wouldn't surprise me if it was sold for that reason. I agree with grossgary's response. It is an old Subaru trick to remove the thermostat when over heating is caused by bad head gaskets. Once done you are able to keep on driving the car without over heating.. The fans may not be coming on, if the engine temperature is low in cold weather, because of no thermostat. Did you get a guarantee, when you purchased this car? Quote Link to comment Share on other sites More sharing options...
luko Posted January 23, 2014 Share Posted January 23, 2014 Fan relays and fan fuses should be under the hood on the left hand of the engine compartment in a block box...coolant temp sensor is on the top right rear of the engine almost under the intake manifold....but check for bad head gaskets as stated above by grossgary Quote Link to comment Share on other sites More sharing options...
msmithmmx Posted January 25, 2014 Share Posted January 25, 2014 Correct me if I am wrong but to test the fans he could reach under the driver side dash and connect those two green service plugs together to test fan functionality. I third the motion for HG issue. Sickening if it is the case. Quote Link to comment Share on other sites More sharing options...
luko Posted January 25, 2014 Share Posted January 25, 2014 msmithmmx I think I remember doing something like that at some point of time with my 01' legy, but not sure Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted January 27, 2014 Share Posted January 27, 2014 Or to test fans on most soobs of that era if you just get the key to run (don't even need engine running) and turn on the a/c both fans will (well should) come on. Quote Link to comment Share on other sites More sharing options...
djmark7 Posted January 27, 2014 Share Posted January 27, 2014 yup fans run automatically with a/c Quote Link to comment Share on other sites More sharing options...
