98 OBW 240K.  I am deep into fixing a suspension issue and this is the last problem or so I think.  The root cause of this is tracked on another thread which I will update when complete.  I was connecting the outer tie-rod to the knuckle yet the castle nut will not tighten past 5 pounds. The threaded post on the tie-rod just spins when it gets any tension.  Is my tie-rod end busted?  I am hoping not as taking this off will pave my way to a front end alignment.  A simple problem has turned into being pecked to death by a thousand chickens.  When I list the parts I have replaced your head will spin.
Edited by msmithmmx
If i am understanding you correctly, the outer tire rod 'cone' is spinning in its socket, i usually get the biggest pair of channel locks/vice grips/C clamp and pinch the tie rod to the knuckle to put some friction in there to get it tight. others may chime in with better solutions, as im no expert by any means.
Edit: i like the jack method better ^.^
Edited by Razorthirty
Just enough to hold it tight, but not enough to lift the wheel off the ground. This works in the opposite way that you can remove a tie rod by whacking the knuckle sharply with a hammer. Tension to fit it, shock to loosen it.
