EA82 swap EJ22 fuel system question.
Suba_GL_87
My 86 gl coupe has an ej22, using an xt6 fuel pump. The car was originally a carb 1.8, using the same lines, although i had to make some adapter fittings between the body and the engine.
The fuel pump is connected directly to the car, and the ej harness is spliced into the bdy harness to run the fuel pump. I made my connection form the harness fuel pump relay to the body harness under the carpet near the door sill on the passenger side.
