Power Steering Leak - Maybe something else?
2000 Legacy L.
I did a fair amount of reading, but had a question or two and thought I would try to get things in order since I may only have 1 shot at this (temps finally getting into the 30's this weekend).
I've got a pretty solid leak from the bottom of the p/s reservoir, most noticeable on the pass subframe. In addition there seems to be either p/s fluid or oil on top of the pass. side head. The low pressure hose on the top of the pump and high pressure hose (has o-ring which is apparently a common leak) aren't leaking (at the pump at least). I don't think the sensor is, but need to double check (if it is, it's only a drop). Does the pump leak underneath by any chance?
My plan is to replace the suction and return hoses (34611AE08A,34611AE09A; which seem like dealer only), and probably the o-ring. Anything else I should check? PCV valve and hoses are clear, guess I need to check the breather on that side though.
Thanks for the help!
Thanks, that's def good to know. Are there o-rings in the bottom of the reservoir? Doesn't appear to be any in this pic: http://opposedforces.com/parts/legacy/us_b12/type_2/steering/power_steering_system/
VC's are in OK shape, don't think they're leaking on top of the head. I guess the back of the pump housing comes apart? Maybe it's leaking at the bottom of that and I can't tell.
Ah I see you have a separate reservoir. The older ones had the reservoir right on top of the pump with an o-ring to seal the two together and a rubber coated washer inside to seal the bolt that holds the reservoir on.
Yes, the case seam does leak on these pumps. That will require at least a partial rebuild to replace. The rebuild kit comes with all new seals, but the front seal is only replaceable by pressing the shaft out, which requires a new bearing, usually not included wih the kit. IIRC is is a standard 6203 rubber sealed ball bearing which is only about $5 at Napa.
Well, I'm 1 step closer. I found the oil pressure switch is leaking prettttty good. It's only like a 15-20$ part, so I'll probably just pop for a new one. Switch works fine as far as i know; any way to just reseal the existing one? Seems like maybe it just uses an o-ring?
