BoostedBoxer421 Posted January 28, 2014 Share Posted January 28, 2014 I have a Rx with ea82t and Gl with ea82t, and was wondering if anybody knew any differences between the engines. First thing I noticed was that the Rx's wastegate goes directly to intake, and on the Gl the wastegate hose goes to a switch then another goes to intake Link to comment Share on other sites More sharing options...
naru Posted January 28, 2014 Share Posted January 28, 2014 Almost the same. Later one has an optical distributor,hotwire MAF and ECU controlled spark,boost and egr. Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted January 28, 2014 Author Share Posted January 28, 2014 how is MAF sensor different? i thought the RX's MAF was bad because its broken, (put it on good engine in GL and it wouldnt stay running) should they work swapped?? the RX had sat for a while and a lot of electrical is bad (fuel pump, MAF sensor, fuel pump relay) and will varnished gas clog up injectors or lines anywhere? if i put gas in throttle body with parts all swapped over from GL (pump, MAF, and pump relay) it will fire but doesnt stay running Link to comment Share on other sites More sharing options...
MilesFox Posted January 28, 2014 Share Posted January 28, 2014 (edited) The 06/87 engine will be an 88 model year. The 01/87 will be an 87 model year. The engine itself is identical, but for 87, some of the pinouts on the harnesses may be different, although schematically identical. For example, the distributor has a round plug for 87 and a square plug for 88 and up. Same for the engine temp sensor, and the knock sensor may be a single pin vs a double pin. When in doubt, use the car's original intake manifold or wire harness on a newer engine. Edited January 28, 2014 by MilesFox Link to comment Share on other sites More sharing options...
Gloyale Posted January 28, 2014 Share Posted January 28, 2014 Both of those should be later style (optical disty, Hotwire Maf, controlled wastegate...etc.) 87 XT kept the old system til the 87-1/2 model change over w/ spider intake. But an RX and a GL from that era should be the same system all the same except as mentioned the connectors could vary as 87 was wonky year. Ref. and Sig wires of disty swapped in 88+ models. Any chance the RX has had the engine swapped? Someone could have swapped the older longblock and turbo into the RX which would explain the direct wastegagte. Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted January 28, 2014 Author Share Posted January 28, 2014 Not sure how to tell if was swapped-anything to look for??? And I noticed the sticker on inside of hood says SPFI on it :/ its exact same color as rest of car too (not too significant considering they're all turbo lol) MAF sensor is exact same but the Rx's is toasted somehow Link to comment Share on other sites More sharing options...
