Demolition Posted January 30, 2014 Share Posted January 30, 2014 Hey guys! I completed my dual range swap but have some questions!! any help would be appreciated! So after my swap everything went okay,,, but eventually my clutch fork bent back,,, So my first question is: Are 4x4 clutch forks a little curved as apposed to 2wd clutch forks or did i bend it? Second what is the proper assembly for clutch forks?? i currently need to replace and have NO idea how to and my Hanes manual doesnt say how.... Car is a; 93 ,loyale, sedan, d/r swap, 5spd, 155k Thanks for any help, I can try to have pictures tomorrow..... Link to comment Share on other sites More sharing options...
zukiru Posted January 30, 2014 Share Posted January 30, 2014 As far as whether you bent it I couldn't say without looking. To replace it you'll have to pull the transmission back out. Link to comment Share on other sites More sharing options...
jono Posted January 30, 2014 Share Posted January 30, 2014 EA82 have one clutch fork part number for the lot from memory Link to comment Share on other sites More sharing options...
MilesFox Posted January 30, 2014 Share Posted January 30, 2014 The difference is the clutch cable if the car was originally FWD. The threaded end on the FWD cable is a different length. I have used a lug nut as a spacer to correct this. Otherwise find the proper 4wd clutch cable and it should fit just right. Link to comment Share on other sites More sharing options...
