BratWarrior Posted January 31, 2014 Share Posted January 31, 2014 Ok... don't kill me for asking this. I am thinking of swapping out the manual D/R tranny for an automatic on my new '84 hatch. This car is going to be my girlfriend's once my BRAT is back in commission and she has no interest in learning stick (this would be her first car). I'm assuming the swap would be straightforward (change tranny and shifter, remove clutch pedal, etc.). Has anyone tried this? Any info would be appreciated. It should be noted that the clutch needs to be replaced on this thing asap anyway. Thanks! Link to comment Share on other sites More sharing options...
BratRod Posted January 31, 2014 Share Posted January 31, 2014 You would need the flexplate, transmission cross member, wiring, the shifter, the plate the shifter mounts to, (requires cutting and welding in place) and I think there is a downshift switch on the pedal... Regardless of what it is. You need that. Need a 3.7 diff for the rear. And I remember reading somewhere that the trans tunnel is smaller on manual cars, which could make swapping an automatic a pain... Don't hold that to me, though. I don't think you have to switch the pedal box from manual to auto, but it would probably be better to have the bigger pedal if its her first car. If you have a whole parts car; the swap shouldn't be that hard. Or maybe it is. I have an auto and manual brat, they're really similar as one would think. Link to comment Share on other sites More sharing options...
idosubaru Posted January 31, 2014 Share Posted January 31, 2014 you'll be installing a 3AT i assume? there's no (or limited) wiring, nor a TCU to deal with, so it's all mechanical and not electrical in nature. that's a good thing. reverse lights would need addressed since they're triggered differently between auto/manual. center console and instrument cluster to clean things up. i've driven without an instrument cluster in numerous Subarus from the 80's to the 2000's so they're not necessary components. ask someone about rear driveshaft - on 4EAT models the driveshafts are different lengths between manual and automatics. Link to comment Share on other sites More sharing options...
Gloyale Posted January 31, 2014 Share Posted January 31, 2014 You would need the flexplate, transmission cross member, wiring, the shifter, the plate the shifter mounts to, (requires cutting and welding in place) and I think there is a downshift switch on the pedal... Regardless of what it is. You need that. Need a 3.7 diff for the rear. And I remember reading somewhere that the trans tunnel is smaller on manual cars, which could make swapping an automatic a pain... Don't hold that to me, though. I don't think you have to switch the pedal box from manual to auto, but it would probably be better to have the bigger pedal if its her first car. If you have a whole parts car; the swap shouldn't be that hard. Or maybe it is. I have an auto and manual brat, they're really similar as one would think. He will not need a 3.7 rear diff unless it's an 83 or older 3at. Trans tunnels are the same size. It's the 4eat they enlarged the tunnel for......in 87 on EA82's Rear crossmember for trans is easy to make out of flat steel. Reverse lights would need wires from the engine bay run inside to the auto Shifter. You'll need to run a vacuum line to the modulator. I don't think there is a kickdown switch on the throttle....I think it's all vacuum controlled.....but I am not sure. Certainly would drive fine without that. 1 Link to comment Share on other sites More sharing options...
BratWarrior Posted January 31, 2014 Author Share Posted January 31, 2014 you'll be installing a 3AT i assume? there's no (or limited) wiring, nor a TCU to deal with, so it's all mechanical and not electrical in nature. that's a good thing. reverse lights would need addressed since they're triggered differently between auto/manual. center console and instrument cluster to clean things up. i've driven without an instrument cluster in numerous Subarus from the 80's to the 2000's so they're not necessary components. ask someone about rear driveshaft - on 4EAT models the driveshafts are different lengths between manual and automatics. I've read bad things about the 3AT on here. I think 4EAT would be the best choice. I would say that an instrument cluster is pretty important for a first time driver! Link to comment Share on other sites More sharing options...
idosubaru Posted January 31, 2014 Share Posted January 31, 2014 (edited) I've read bad things about the 3AT on here. I think 4EAT would be the best choice. I would say that an instrument cluster is pretty important for a first time driver! the 3AT sucks for some reasons but others familiar with subarus also say they are reliable if you take care of a few minor issues - governor or something, i've never owned one but Johnfromky and others have said they can be decent for plain daily driver use. swapping a 4EAT would require a complete wiring harness and grafting it into appropriate signals - at least the TPS and probably more. it would substantially more work. if you're capable of doing a transmission swap then you're capable of also buying a car cheap needing work and fixing it - which would take less time probably. there is one simple 4EAT option that would be very easy but you may not like it. if you swapped a 4EAT in there and ran it without any wiring or TCU it would function fine. it would run in purely mechanical mode and always be in 3rd gear and always have the 4WD locked. i've done it in XT6's with 6 cylinder engines and they have plenty grunt to make them fine as daily drivers even around here in the mountains. slowest off the line obviously but not too bad. an 80's 4 banger may not. locked 4WD is easy - just splice into the one Duty c wiring and control it yourself - FWD or locked 4WD. indeed i wasn't saying to run without a cluster! that would be awful for anyone. i was just saying it would at least be movable with an instrument cluster and driveable for testing/finishing up, not that you'd want to keep it that way in any case. it is odd driving not knowing your speed or volts, or oil pressure or anything. sometimes i like to know, with a project, what is going to get me on the road driving and what's going to hold it up. Edited January 31, 2014 by grossgary Link to comment Share on other sites More sharing options...
rdweninger Posted February 1, 2014 Share Posted February 1, 2014 Ok... don't kill me for presenting this option... but I just can't help myself. Keep the stick shift and find a new girlfriend. Problem solved. 1 Link to comment Share on other sites More sharing options...
mr sarcastic Posted February 1, 2014 Share Posted February 1, 2014 That's seems easier. Or, negotiating something so she'll learn how to drive a manual. Both options sound easier then swapping the drivetrain. Link to comment Share on other sites More sharing options...
BratWarrior Posted February 1, 2014 Author Share Posted February 1, 2014 Ok... don't kill me for presenting this option... but I just can't help myself. Keep the stick shift and find a new girlfriend. Problem solved. HAHAHA! Nah, She's a keeper and helped me buy my BRAT and hatch. She's definitely a old school Subaru supporter. I'm thinking I might just do the clutch job and make her learn stick. Link to comment Share on other sites More sharing options...
mr sarcastic Posted February 2, 2014 Share Posted February 2, 2014 It's something everyone should know how to do. Link to comment Share on other sites More sharing options...
wagonist Posted February 2, 2014 Share Posted February 2, 2014 In terms of the instrument cluster, the only difference is the shifter position for the auto. Completely unnecessary, use your eyes & look at the gearstick. I'm really surprised no one else has mentioned the neutral safety switch. This is so the car will only start when the auto is in neutral or park. VERY IMPORTANT You'll need to interecept the starter motor wire from between the ignition switch & starter motor. I'm not sure where the switch is, but for the 3AT I'm guessing on the gearstick itself. If you've already got a 3AT gearstick, you'll see 2 wires that are thicker than the rest. Connect one to the ignition switch & the other to the starter motor. You'll also need to run an illumination wire from the dashboard to the selector. Again, this is a safety item so you know which gear is being selected at night. If you want, run both so that this light dims with the rest of the dash, but it's not necessary. Link to comment Share on other sites More sharing options...
