madkow007 Posted May 1, 2004 Share Posted May 1, 2004 Hi all Car...89 wagon D/R 5 speed ea82 non turbo. Now for the Q. I need to replace the gas tank...so have to drop the diff from what I understand. I was looking at the bracket that holds the diff to the car...it looks like there is a rubber bushing in it...is this true? And if thats what it is...it looks to bad in very bad shape. SOOOO...is it a rubber bushing? If so...does anyone know where I can get a new one?? :-\ Thanks for any help with this. MOOOO Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 1, 2004 Share Posted May 1, 2004 It is a rubber bushing, but it's molded right into the hanger. I haven't personally seen one go bad except in situations where the hanger is bent, and the rubber stayed at a funny angle for a long time. Only way I could see to replace it is to replace the whole hanger. Likely it's just fine tho. I wouldn't worry about it. You could fill in the holes in the rubber with urethane if you wanted. GD Link to comment Share on other sites More sharing options...
madkow007 Posted May 1, 2004 Author Share Posted May 1, 2004 Thanks GD That makes me feel better Must be the rubber is chewed up on the edges some is all. That solves problum Link to comment Share on other sites More sharing options...
subyrally Posted May 1, 2004 Share Posted May 1, 2004 im kinda in the same boat on this one, i need to drain and drop the tank, its been sitting for 6 years and prolly has more water than gas in it, strangly enuff, the car still runs on it. Link to comment Share on other sites More sharing options...
MilesFox Posted May 1, 2004 Share Posted May 1, 2004 it maight look like its separated, but that is how its supposed to be. you will understand once you have it apart. Link to comment Share on other sites More sharing options...
madkow007 Posted May 1, 2004 Author Share Posted May 1, 2004 Yes...thank you Miles I see how it is now...kinda like the ones in the mustash bar. This sure is turning into a messy job...lol I should have checked that the contaner that I was draining the gas into didn't leak better...kitty litter...garage floors best friend (next to a good seal) Link to comment Share on other sites More sharing options...
