nkmilesAE95 Posted February 4, 2014 Share Posted February 4, 2014 I did a bit of searching and couldn't find much about this topic - so i shall ask. I have an 88 GL Turbo and eventually want to re-route the exhaust as i am lifting the car, and i want to upgrade the exhaust. When i do this, i want to put a high flow cat and possibly a magna flow muffler. I also plan to bump up to 2.25" or 2.5" pipe. Has anyone out there upgraded the exhaust on an EA82T? What did you use? Pipe diameter?? - this is my main concern as i know a high flow cat is a high flow cat, and mufflers are pretty much a preference for sound etc. Any suggestions would be stellar. My goal is to boost performance a bit and to make that little EA82T boxer sound good. Cheers Nate Link to comment Share on other sites More sharing options...
john in KY Posted February 4, 2014 Share Posted February 4, 2014 Used 2.25 on my 90 turbo wagon. Went with that size because when I cut the flange at the turbo off, 2.25 size pipe was a perfect fit. Muffler used was a straight through turbo design. Noise was minimal, actually very quite. Link to comment Share on other sites More sharing options...
rpholz Posted February 5, 2014 Share Posted February 5, 2014 TWE header, td04, modified 3" wrx down pipe, 3" catback with a 18" resonator, no cat or muffler Crazy loud and would never pass an emissions test. 1 Link to comment Share on other sites More sharing options...
