84 subaru gl wagon 4wd problems
i have an 84 gl wagon and my rear wheel drive works perfectly in high and low range but when i put it in 2wd the front will not work !!!!!!
 i foun a rod that goes to the front from the 4wd stick and ive moved it in all directions and posible configurations but i just cant fgure this out .
 and help would be great !!!!
Correct. Get someone to put it in gear in 2wd and try to drive it. Peek under the car and look to see which axle is spinning - you found your culprit. If the CV is ok, the front hub is likely stripped. You can get a replacement from an auto yard pretty cheap. Not too hard to replace either unless the car is really rusty.
Thanks for the help!!! It's snowing here so I'll let y'all know what I find out !!! Also is there any where to get a manual for this baby I'm having run ability issues .... I'd like to get them sorted out
These are the best ones http://www.ebay.com/itm/SUBARU-1600-1800-SERVICE-MANUAL-ENGINE-AND-BODY-1984-MSA118-/321315063304?pt=Motors_Manuals_Literature&hash=item4acfdec608&vxp=mtr#ht_52wt_908
