Phizinza Posted February 7, 2014 Share Posted February 7, 2014 Following on from my last thread http://www.ultimatesubaru.org/forum/topic/144159-help-4eat-97-outback-torque-converter-seatingbroken-trans/?do=findComment&comment=1211545 Now this Trans is empty of oil, will its oil pump self prime once I've refilled it? Or do I have to pump oil into it somehow (through a hole on the box somewhere)? Link to comment Share on other sites More sharing options...
john in KY Posted February 7, 2014 Share Posted February 7, 2014 I think you are good to go as long as the TC has fluid. Link to comment Share on other sites More sharing options...
Phizinza Posted February 7, 2014 Author Share Posted February 7, 2014 The TC isn't full, but has ATF in it, probably a litre.. Link to comment Share on other sites More sharing options...
nipper Posted February 7, 2014 Share Posted February 7, 2014 As long as there is sufficient fluid in the pan it will it will pump up. Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 7, 2014 Share Posted February 7, 2014 If there is little fluid in the trans or converter it will suck the pan dry shortly after starting. The whole thing holds around 11 quarts of fluid IIRC. Put 4 or 5 in the pan before starting, run it for 20-30 seconds, and check the level, add until its full. Don't let the pump run dry or it may burn up. Link to comment Share on other sites More sharing options...
Phizinza Posted February 7, 2014 Author Share Posted February 7, 2014 I filled the pan with 3 litres, started it, stopped it, filled another 2 litres, started it, went through P-R-N-D backwards and forward a few times, stopped, filled another 2 litres, took it for a drive, and then another litre and finally it sat on hot full mark after a minute of rest in park with the engine running.. Thanks for the help, looks like the transmission is good now Link to comment Share on other sites More sharing options...
