EA82 driveaxle/CV joint spring pin source?
I need to replace the rear wheel bearings in my 4WD '91 Loyale wagon sometime soon, so I'm ordering the parts today.
When I did one of the front bearings last summer, I reused the original spring pin when I reconnected the inner CV joint to the differential, although my trusty Haynes manual said to "be sure to use a new spring pin." Since I didn't *have* a new spring pin, I used the old one and it seems to have stayed put.
For the rear wheel bearings, I'm actually planning ahead instead of waiting for the bearing to fall apart (whoa!). So if I can find a source for new spring pins (apparently with the rear driveaxle, there are spring pins at both the inner CV and outer CV joints). Anyone know where these spring pins can be acquired one their own, without buying a replacement half shaft assembly? Because in the words of my wise companion Haynes, "be sure to use new spring pins."
Thanks for any pointers you can offer.
- Brooks
