Remove the glove box and the liner behind it, and you should be able to wiggle it out.
If not there are one or two bolts in the lower corner of the dash, and one bolt on the side behind the D shaped cover. Remove those and you can pull the lower corner of the dash out an inch or so and that should give enough room to drop the blower out.
