Lowrider Posted February 10, 2014 Share Posted February 10, 2014 How do I remove blower motor in a 95 Legacy Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 10, 2014 Share Posted February 10, 2014 Remove the glove box and the liner behind it, and you should be able to wiggle it out. If not there are one or two bolts in the lower corner of the dash, and one bolt on the side behind the D shaped cover. Remove those and you can pull the lower corner of the dash out an inch or so and that should give enough room to drop the blower out. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted February 10, 2014 Share Posted February 10, 2014 The blower motor may not work because it is full of leaves and crud that prevent it from working. If so, cleaning out the mess generally gets the blower to work again. That is what I found out some time back. Quote Link to comment Share on other sites More sharing options...
