shapay23 Posted February 10, 2014 Share Posted February 10, 2014 Hi i recently bought a subaru impreza ej16 sohc non turbo and i think i have change everything on there such as filters, oil and plugs and plug leads but i still have bad gas mileage and i also notice it has this real slow response when i'm taking off, even when i'm driving and i mash down it hugs back and then takes off like a bat out of hell. What could be the reason for all this to be happening. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 10, 2014 Share Posted February 10, 2014 Welcome! Is your EJ16 Carburated or EFi? Link to comment Share on other sites More sharing options...
shapay23 Posted February 11, 2014 Author Share Posted February 11, 2014 it's EFI, when i checked online i read that parts of the enigne were curbarated but i doubt it seeing it was manufactured in the year 2000 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 11, 2014 Share Posted February 11, 2014 Yes, only the very early EJ15 and EJ16 were Carburated. So, since your EJ16 is EFi and writing about its fuel economy... the bad fuel economy and the slow response that changes to fast response only if you floor the gas pedal, could be done by some different causes; let's start from the Basics: Dirty fuel injectors and something wrong with the Throttle Position Sensor or its Wirings. Kind Regards. Link to comment Share on other sites More sharing options...
shapay23 Posted February 11, 2014 Author Share Posted February 11, 2014 I've used fuel injector cleaner but still the same action, the throttle position sensor i will have to look at. Thanks. Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 12, 2014 Share Posted February 12, 2014 Is there a knock sensor on the EJ16? (We never got that engine in the US) Is there any difference when the engine is cold vs when its warmed up? Link to comment Share on other sites More sharing options...
shapay23 Posted February 13, 2014 Author Share Posted February 13, 2014 yes there is a knock sensor, actually had to replace it when i first got the car. The car runs well after awhile but hot or cold it still has this hesitant move as i press down from a stand still position or a rolling position. Link to comment Share on other sites More sharing options...
rverdoold Posted February 14, 2014 Share Posted February 14, 2014 Some questions to fill in! Milage/KM: Build year: AT/MT: 2wd/awd: last valve clearance adjustment: What oil did you put in (synthetic, and viscosity): Timing belt: could timing be off? that would be bad. Was it replaced? I have a 1.6 on LPG but also still runs on gasoline. I found this motor very throttle aggressive (not so smooth compared to 2.0 or 2.5). The fuel efficiency is not that good due to the low motor output, unless you do not increase over 3,000 rpm Link to comment Share on other sites More sharing options...
shapay23 Posted February 18, 2014 Author Share Posted February 18, 2014 (edited) milage: 221797km year: 2000 AT 2wd last valve clearance adjustment I really don't know I use 10/30 shell oil i have never check the timing belt or changed it. Edited February 18, 2014 by shapay23 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 18, 2014 Share Posted February 18, 2014 ...i have never check the timing belt or changed it. Well, after fourteen years and 221K kilometers ... ... that timing belt could be about to snap in no time, maybe already has jumped a couple of teeth! ... it happened to my Subie some years ago, the Timing belt was so old that had some missing teeth. I Kindly suggest you to check that Timing Belt / Replace Timing kit as soon as possible. Kind Regards. Link to comment Share on other sites More sharing options...
luko Posted February 18, 2014 Share Posted February 18, 2014 O2 sensor as well...could be giving your PCM false readings...or you could have a dirty MAF Link to comment Share on other sites More sharing options...
shapay23 Posted February 19, 2014 Author Share Posted February 19, 2014 Ok will do. Link to comment Share on other sites More sharing options...
rverdoold Posted February 19, 2014 Share Posted February 19, 2014 O2 sensor as well...could be giving your PCM false readings...or you could have a dirty MAF I am not sure my 99 EJ16 has a MAF, i think it is calculated from intake air temperature and atmospheric pressure. Note that the ej16 is the most basic model you could get. I would for sure check the timing belt it should have been done at 100k and 200k, valve adjustments are every 60k (all KM) as far as i remember. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 19, 2014 Share Posted February 19, 2014 ...Note that the ej16 is the most basic model you could get... It depends on the Market, the very basic impreza came here with EJ15. Kind Regards. Link to comment Share on other sites More sharing options...
rverdoold Posted February 20, 2014 Share Posted February 20, 2014 It depends on the Market, the very basic impreza came here with EJ15. Kind Regards. Did the ej15 not replace the ej16, in Europe it did 1995 to 2005 = ej161 2004 to now = ej15 20013 to now is ej16 (new one) with CVT in impreza Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 21, 2014 Share Posted February 21, 2014 Sorry for the Thread Hijack... The LADM (Latin American Domestic Market) had the 1.5L EJ15 engined impreza in the very basic model: Manual transmission, no 4wd nor power windows nor power locks... while the 1.6L EJ16 engine came with the same basic impreza, but with Automatic transmission. Seems like the 2000 impreza from the original poster is 2WD automatic EJ16, like the LADM Specs imprezas, see: milage: 221797km year: 2000 AT 2wd last valve clearance adjustment I really don't know I use 10/30 shell oil i have never check the timing belt or changed it. End of thread Hijack... Kind Regards. Link to comment Share on other sites More sharing options...
wtdash Posted February 22, 2014 Share Posted February 22, 2014 Hi, Did you replace the fuel filter as part of your filter maintenance? Also, does it rev freely in Neutral/Park? GL, TD Off-topic but I can't imagine.. 2013 to now is ej16 (new one) with CVT in impreza ...does this come w/extra passengers - to get out and push up hills??? Makes ~114HP and ~111 ft-lbs (slightly more than the old US EJ18) and it weighs ~3K lbs. 0-100 km = 12.6 secs. AWD/11.8 - FWD, BUT it gets combined 38+ MPG! Link to comment Share on other sites More sharing options...
rverdoold Posted February 22, 2014 Share Posted February 22, 2014 The old ej16 is big fun in the alps, have to rev constantly to >3500 rpm to get up the 'hill'. Link to comment Share on other sites More sharing options...
forester2002s Posted February 22, 2014 Share Posted February 22, 2014 Have you tried higher-octane fuel? Perhaps the knock-sensor is doing its job. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 22, 2014 Share Posted February 22, 2014 The old ej16 is big fun in the alps, have to rev constantly to >3500 rpm to get up the 'hill'. Just like our Old-School EA82 Subies ... ... Link to comment Share on other sites More sharing options...
shapay23 Posted March 3, 2014 Author Share Posted March 3, 2014 Well it doesn't have a o2 sensor neither the hole for it but it does have the connection....I changed everything. I realize thou that the transmission shifts 1st and 2nd reasonably well but third has the slow build up; I was wonder if its because its not turbo charge and also a single cam why it reacts this way. Seems like it doesn't shift out of third when i slow down so when i accelerate i get the sluggish movement. Link to comment Share on other sites More sharing options...
