logic23 Posted February 11, 2014 Share Posted February 11, 2014 I was looking to get some advice on a couple 2001 2.5 sohc engines I am rebuilding. Today i miked the main and rod bearing on both cranks and got readings as low as 59.95 ( postion #2) most were 59.98. The book I have says that 59.992 is the min. Any suggestions? polish ? regrind? Thanks Link to comment Share on other sites More sharing options...
Bushwick Posted February 11, 2014 Share Posted February 11, 2014 Is the book saying 59.992 or 59.92? Link to comment Share on other sites More sharing options...
ocei77 Posted February 12, 2014 Share Posted February 12, 2014 (edited) If you don't have it, download the FSM. Search the sticky above for FSM. When you look at the crank there should be a group of 5 letters, ranging from A to maybe D. Each letter represents a tolerance range. Attached is the engine spec sheet JIC. A is std. ,B is .03,C is .05 and D is.25. Should also be a group of 4 letters for the rod bearings. Haven't been able to decipher those. Unfortunately cranks are not generally all one size from the factory. You can buy separate main bearings from Subaru, but not rod bearings. If it is within your budget, would be easier to have them all machined to the same size. O. general description.pdf Edited February 12, 2014 by ocei77 Link to comment Share on other sites More sharing options...
logic23 Posted February 25, 2014 Author Share Posted February 25, 2014 Thanks ocei77 for the words and PDF. Link to comment Share on other sites More sharing options...
ocei77 Posted February 25, 2014 Share Posted February 25, 2014 my pleasure O. Link to comment Share on other sites More sharing options...
