Should this hole in air cleaner housing be blocked?
There is a hole in the front-bottom of the air cleaner housing of my 85 GL. I'm guessing that it is a drain hole for moisture. There is a weird blue object placed in the hole (I'm guessing by the PO). Does anyone have a plug, of some sort blocking this hole?
I've never heard of an open hole in the intake system down stream of the air filter...
I say plug it.  you are just asking for dust and dirt to enter...path of least resistance...
it was probably for a fastener or clip of some type...maybe a plastic retainer clip to hold a vacuum line neatly in place underneath the air cleaner housing to keep the engine bay tidy?
