Tofutti Posted February 17, 2014 Share Posted February 17, 2014 ..And probably one that has been asked before, but after a couple hours of searching here, I haven't found an answer.1992 Loyale has original all-metal radiator that actually doesn't leak, but the fins are mostly corroded and have flaked away, thus not cooling well. Does alright most of the time, but pulling a hill during the summer requires full heat on to keep the temp in-check. This is a fairly low mileage engine and I'm not willing to let this slide and risk it anymore.I'm finding both types of replacement radiators available: All-metal (CSF Model #933), and Aluminum-core with plastic tanks (APDI/ProRad Model #8010935).I know there are pros and cons for each type, and I've read various opinions on other forums, but I'd rather take advice from a more vehicle-specific point of view. There is only a $40 price difference that I'm not terribly concerned about.Thoughts? Opinions? Experiences? What would YOU do, or what have you done?Thanks. Link to comment Share on other sites More sharing options...
ruparts Posted February 18, 2014 Share Posted February 18, 2014 my opinion is to use the all metal, brass copper and find the 2 rows of cooling tubes version since you are buying new , not all places have them , but they are minimally more expensive and almost double the cooling capacity of the single row. 1 Link to comment Share on other sites More sharing options...
suprjohn Posted February 18, 2014 Share Posted February 18, 2014 I did the plastic from rock auto since I'm broke and cheap. So far, so good, though I've not driven it much. This was part of a general cooling system overhaul, and so far my '89 DL runs VERY cool. Almost too cool. But summer's comin' :-) John Link to comment Share on other sites More sharing options...
Sdam87 Posted February 19, 2014 Share Posted February 19, 2014 I gotta get a rat for my car (same year as yours) This is what Im going to get/do. Granted it's a single row http://www.fcpimport.com/products/subaru-radiator-45181-ga690 Link to comment Share on other sites More sharing options...
silverback Posted February 21, 2014 Share Posted February 21, 2014 What ruparts said: 'double row'. Also use a Subaru thermostat. The pellet is larger than aftermarket units. Check the thermoswitch for your fan. Link to comment Share on other sites More sharing options...
NorthWet Posted February 21, 2014 Share Posted February 21, 2014 Copper core is superior in all ways except cost and weight to aluminum core. Dual-row core is hard to find, generally need to search on a TURBO model, and only provides perhaps 50% more heat-transfer capacity (diminishing returns on multi-core radiators). Link to comment Share on other sites More sharing options...
silverback Posted February 22, 2014 Share Posted February 22, 2014 NorthWet is spot on about the 'TURBO' part of the search. Assuming EA82, I believe all flavors of radiators for EA82's will fit into all EA82 platforms. An aid in searching maybe; 4WD, TURBO, AT for a double row unit. Perhaps a 1989, 4WD, TURBO, AT may work. Good luck with the search. Link to comment Share on other sites More sharing options...
