reupholstering door panels
Hey All,
twenty years of sun, sweat and abuse has left my door panels in pretty rough shape. as we know, no one reproduces these door panels, so i decided to take a run at reupholstering them myself. i ordered some foam backed vinyl and 3m adhesive and after an afternoon of cutting an gluing, i have a mostly acceptable result. not perfect, but fine for a daily driver. heres some pics.
next, i think i'll paint the door pockets and mount my new speakers.
john
  • Like 1
Only suggestion I'd make is either shave some of the foam around the rectangular hole, or, make a small block of wood the size of the plastic bezel & compress the vinyl so the bezel fits better. Had a time getting the bezels in place on my 87 GL after the upper panels were redone. Caused the electric door locks to hang up a little too because the bezels were in the way of the rods. Too much foam behind the vinyl.
Just a suggestion.;)
  • Like 1
Hey Sdam87, 5.25" in the front, 6.5" in the rear.
I wanted to mount the fronts in the stock location, but found that the speakers were deep enough that they wouldn't let the window roll down. They will be surface mounted instead. I ran all new wiring instead of trying to hack into the stock speaker wiring. Here is a pic of how the fronts will be mounted.
C40CB890-C961-480B-AB3F-588C08474C14_zps
B2798DF8-CB31-4CF4-90D3-B9E7861BF767_zps
John
