87 hatchy wants to live
   So if you havent seen my members ride thread youll be delighted to read this. I apologize for the redundancy but I dont wanna clutter that thread unnecessarily, and would like to reach the rest of you folks. Car drove to where i bought it and sat for two years.
   Im having an issue where im starving for fuel even though both filters remain full and clean. I can hear the fuel pump working away.
Car will start, and run. then if gas is applied or a load put on, it bucks, surges, and dies in short order. car has an o2 sensor so that would mean I have the illustrious feedback hitatchi right?
confirmed vac advance, spark are both good.
advice?
so....after blowing out gas lines and general research/dinkin around i found a problem.....backwards fuel tank filter. facepalm. tuned the carb, adjusted timing. purrs like a kitten now and even went up the block a couple times. still has a little starving symptoms under heavy acceleration. for now i will attribute this to the fuel filter i probably ruined. opinions?
i did have a check engine light off and on when i brought it home...i hope my o2 sensor doesnt need replacing
