lmdew Posted February 24, 2014 Share Posted February 24, 2014 Trans was rebuilt a few years ago by Aamco according to the PO. The front diff went on it, low gear lube i suspect, there are chunks in the diff. According to the yards and www.car-part.com the trans requires a 2002 or 2003. Think it's worth changing out the front Diff? Anyone with a Trans in CO? Thanks Larry Link to comment Share on other sites More sharing options...
ShawnW Posted February 25, 2014 Share Posted February 25, 2014 Its not too bad a job. Gotta pull the tail housing and the front to do it and use the ring with the trans you are getting the front diff from's pinion shaft. Link to comment Share on other sites More sharing options...
lmdew Posted February 25, 2014 Author Share Posted February 25, 2014 Thanks, There is a 2001 at the Aurora UPAP that was hit pretty hard in the front. parts of the engine are still there and the trans is there. Someone pulled the half shafts without removing the roll pin so they pulled the stub shafts out as well. Think I'll just watch the COS UPAP and wait for one to come up. Link to comment Share on other sites More sharing options...
idosubaru Posted February 25, 2014 Share Posted February 25, 2014 Its not too bad a job. Gotta pull the tail housing and the front to do it and use the ring with the trans you are getting the front diff from's pinion shaft. Shawn - so you use the donor trans ring and pinion. Do you need to use the donor trans tail housing and front case or other parts to keep the shim/distances/backlash set the same? There's another thread from a guy that did just this on here too, I'm in the middle of cobbling together a trans from two on a 2002 H6. Link to comment Share on other sites More sharing options...
