center console wiring harness, extra plug?
odie
85 Brat...the wiring bundle that goes to the center console...4 plugs total...1 is the light for the ashtray.  2 are for the OEM radio.
the 4th plug went no where...I'm guessing optional seperate tape deck???  has 7 wires going to it.post-49716-0-05034600-1393279060_thumb.jpg
power windows on an old Brat????  well it does have the cruise control too which I thought was kinda over board on an 80's economy brand.
I also have a rear? defroster switch, which has power to it...but there is no rear defroster???
They only made one heating/cooling panel cover to save money. Brats do not have a rear defroster but wagons, hatchbacks, sedans, and coupes do. I put in the cover the other day in my wagon from one out of a brat which is the same exact piece you just have to push the plastic cover out and screw the switch in.
trick is to find the other end of the plug that the relay attached to.  Prob under near the fuse box.  I've got several un-plugged plugs... but my brat seems to have had some hack jobs in the past...or one universal harness for all models and option possibilities (gl, dl, wagon, etc)?  Often it's cheaper to manufacture one "all-in-one" harness.
  On 2/25/2014 at 11:13 PM, 86BRATMAN said:
It's pretty much like that, the gl's that I've seen have a pretty standard body front body harness and dash harness, the dl's are the same way, from dash back it varies depending on body type.
So in theory my 88 DL should have the wiring/plugs already for power options (mirrors, locks, windows) then?  If so, then sign me up for those upgrades :D
Edited by TheWanderer
  On 2/26/2014 at 12:24 PM, Dinky26 said:
So all the Brat GLs should have a plug for power mirrors?
That would be kinda nice, just have to find the power mirrors, since I have a controller switch already.
you'd need the door wiring harnesses too.
wow...you got a complete pic of that dash harness with all the plugs labeled?  would be nice to know what all the un-connected ones go to.  I'm always wondering if I should be trying to plug them all in or not worry about it.
Factory manuals come in handy with some of this stuff and having cars that came with everything helps too find out where stuff goes. I remember seeing a link to a factory manual download on here maybe some has it and will chime in. There are a lot of test plugs on the harness to test voltage and resistant so there will be a few that don't go anywhere.
