ARJ Posted February 27, 2014 Share Posted February 27, 2014 I there any reason why I cant fit a EJ20 or EJ22 into a brat brumby and run it as a rear wheel drive only ?? Has anyone ever done this before sounds a lot easier than doing the AWD bit . Maybe do the AWD change later ?? Any ideas ARJ Link to comment Share on other sites More sharing options...
idosubaru Posted February 27, 2014 Share Posted February 27, 2014 (edited) EJ into EA has been done a bazillion times EJ turbo into EA has been done countless times RWD has been done before. a failed EJ VLSD, which isn't terribly hard to find as people throw them away when they repair them, will be permanently "locked" in 4WD - install that and don't install the front axles and you have RWD. or use an EA trans with center diff lock and lock it. have to install the outer CV cups into the hubs to hold the front bearings together/seal them. i did the same thing when i converted one of mine to FWD - disassembled a rear axle and slid the outer cups into the rear knuckle/hub assembly. have at it. Edited February 27, 2014 by grossgary Link to comment Share on other sites More sharing options...
