ARJ Posted February 28, 2014 Share Posted February 28, 2014 IS IT POSSIBLE TO CHANGE THE DIFF RATIO ON A BRUMBY TO 4.11 JUST WANT UP GRADE THE OLD EA82T TO A EJ20 NON TURBO NOT AFTER A HOTTY JUST A RELIABLE MOTOR AND A AWD SET UP RATHER THAN THE HI LOW 4 WHEEL DRIVE BOX AS PARTS ARE NO LONGER EASY TO OBTAIN AND VERY EXPENSIVE ARJ Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted February 28, 2014 Share Posted February 28, 2014 just swap in the rear diff from the donor vehicle, and quit using all caps haha Quote Link to comment Share on other sites More sharing options...
ARJ Posted February 28, 2014 Author Share Posted February 28, 2014 Thanks did not know if that is possible due to the Brumby's rear suspension set up with torsion bars . So it isn't a big hassel to change the diff ? Ha no all caps was half way through when notice caps on to lazy to rewrite ARJ Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted February 28, 2014 Share Posted February 28, 2014 if the different diff has a different number of teeth on the splines, you have to make some hybrid axles, which really isnt that big of a deal. its impossible to change gear ratio in the stock one, because nobody makes aftermarket ones Quote Link to comment Share on other sites More sharing options...
ARJ Posted February 28, 2014 Author Share Posted February 28, 2014 Gotcha thanks understand what you mean Quote Link to comment Share on other sites More sharing options...
