disom93 Posted February 28, 2014 Share Posted February 28, 2014 Randomly the steering wheel on my 80 brat will shimmy like when going down road. Is this tie rod ends or what? Link to comment Share on other sites More sharing options...
Dinky26 Posted March 1, 2014 Share Posted March 1, 2014 Here are the items I replaced on my Gen2 1. Ball Joints 2. Inner tie rod end 3. Lower control arm bushing 4. Strut rod bushing 5. Steering Gear Mounting Bushing Seemed to clear up my shaking issues. Link to comment Share on other sites More sharing options...
Dj7291993 Posted March 1, 2014 Share Posted March 1, 2014 Is it most common when braking, accelerating, or cuising? If it's when braking, you're most likely looking at warped rotors. Rotors on these are pretty cheap since there's not much to them. You could change them now, or wait 'till your pads wear out. Link to comment Share on other sites More sharing options...
the sucker king Posted March 1, 2014 Share Posted March 1, 2014 out of balance tire is a common cause if you get up to speed and it starts shaking. check to see if you threw a weight. Link to comment Share on other sites More sharing options...
TheYeti Posted March 1, 2014 Share Posted March 1, 2014 out of balance tire is a common cause if you get up to speed and it starts shaking. check to see if you threw a weight. If this doesn't fix the issue, check your axels. Axels/worn CV joints can also cause some shaking in the wheel as well. Link to comment Share on other sites More sharing options...
TheWanderer Posted March 1, 2014 Share Posted March 1, 2014 Another item to check that is often overlooked is your wheel bearings. Every Subaru I've owned seemed to lunch wheel bearings in short order (I swear they eat em for breakfast), and they all tended to shimmy shake a bit. My Legacy had wheel bearings with 1.5" of play in em on the front, and my gawd was that awful to drive above 30 mpg lol Link to comment Share on other sites More sharing options...
disom93 Posted March 1, 2014 Author Share Posted March 1, 2014 Ok and its mainly when cruising. Its not horrible bad but i can feel it Link to comment Share on other sites More sharing options...
disom93 Posted March 1, 2014 Author Share Posted March 1, 2014 And i dont believe its tires cause i just changed tires for summer snd still does it slightly i can feel it in the sterring wheel mostly Link to comment Share on other sites More sharing options...
