Clutch kit non-OEM (incl worn snout sleeve) quality question
Hi folks,
New member here. Joined the other day in order to get started on research for a clutch replacement in my '99 Subaru Legacy Outback 2.5L (228,000 miles---purchased at 198,000).
I've got a gearhead friend helping me with the repair in 3 weeks, and doing all the reading and Youtubing I can in the meantime. Seems like we'll be able to pull this off. I'm close to pulling the trigger on a clutch kit, but had a question about non-OEM kit quality.
I was planning to just pick up the Exedy OEM kit (KSB04):
http://www.rockauto.com/catalog/moreinfo.php?pk=2392652&cc=1389405
However, a friend said it's very worthwhile to go ahead and grab a kit that contains a worn snout sleeve---also called PDM sleeves. I checked out the video here which is very good for describing the issue and its solution: http://allwheeldriveauto.com/subaru-repair-seattle-transmission-housing-repair-kit/
Now, the sleeves on their own are pretty pricey at some suppliers, ballpark $150. That's on top of a clutch kit, which would be $140 or $150 for OEM at Ebay or Rock Auto (link above).
On the other hand, there are some kits that include the sleeve, and my friend indicated that these are significantly cheaper in part because it's a different method of fabrication. Specifically, I'm looking at AMS Automotive part 15004R. Here's the link: http://www.rockauto.com/catalog/moreinfo.php?pk=1524032&cc=1389405
Questions:
1. Should I be overly concerned about the drastic difference between the price of fancy Six Star sleeves sold by specialty suppliers, and the ones included in kits like the AMS kit I linked above?
2. How is the quality of AMS clutch kits?  They advertise "rigorous OEM spec" - but does that mean I'm guaranteed the same quality as an OEM Exedy kit? If there's any doubt, I would prefer to go with Exedy. I don't know where AMS kits are manufactured. Should I worry about this? I don't want this to give out after another 20,000 miles!
Thank you. I'm happy to answer any follow-up questions if any of this is unclear. This will be my first clutch replacement so I'm learning a lot as I go.
