gsac132 Posted March 4, 2014 Share Posted March 4, 2014 I just purchased my second Suby.It has a check engine light on and when I went to pull the code the scanner could not communicate with the scanner,What's the best way to address this issue,should I wire a new plug on it?I really don't know what to do I never had one that didn't work.what would you do? Link to comment Share on other sites More sharing options...
jp98 Posted March 4, 2014 Share Posted March 4, 2014 Did the scanner power up or did it just do nothing. A common cause is a blown fuse. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 5, 2014 Share Posted March 5, 2014 what year soob? OBD II is 96 and up, some 95s may have had it. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 5, 2014 Share Posted March 5, 2014 Pull the panel down and make sure all the pins are pushed into the connector all the way. Have seen mention here several times of pins being backed out of the plug, and that would certainly cause the scanner to not communicate. Link to comment Share on other sites More sharing options...
gsac132 Posted March 5, 2014 Author Share Posted March 5, 2014 Did the scanner power up or did it just do nothing. A common cause is a blown fuse. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 5, 2014 Share Posted March 5, 2014 what year soob? OBD II is 96 and up, some 95s may have had it. DOH! 98 Test the scanner on another car to confirm it's working. Has that scanner actually been used on your other Subaru? There were some inexpensive scanners that wouldn't communicate with the ISO protocol. Link to comment Share on other sites More sharing options...
gsac132 Posted March 5, 2014 Author Share Posted March 5, 2014 Yes it powered up Link to comment Share on other sites More sharing options...
