Outback BH clutch/flywheel compatibility?
Hi, I have a EJ25 from a BH outback with flywheel. I need a clutch for it though. Does anyone know if the EJ22 clutch will bolt on and work? I plan to run it on an older EJ gearbox with cable clutch where as the Outback has a hydraulic clutch.
Thanks,
