RedGTLegacy Posted March 14, 2014 Share Posted March 14, 2014 Car Information: 1997 Subaru Legacy GT Sedan, 2.5L DOHC Hi there, Im hoping that someone may be able to tell me why the ignition coils I had delivered for my car are not the correct ones, I've searched and searched and every coil-pack I come across is depicted as the ones I received. However the stock pack I'm attempting to replace Is a much smaller pack: Diamond F-560. The new pack will not bolt and does not possess the same connecting pin. My engine has not been swapped, I know it is a 2.5L EJ25 as I had the timing belt done about a year ago. I've been reading that my year was a "transition" year and that I may have a certain type of pack. Does anyone know about this? I'm really looking forward to continuing my troubleshooting for a misfire and I was hoping this might have been the fix. Thanks in advance for the time! Link to comment Share on other sites More sharing options...
natetru Posted March 14, 2014 Share Posted March 14, 2014 i also have a 97, built in October....recently did headgaskets. the valve cover seals were incorrect and after going thru some hoops found I had valve covers from a pre transition motor....so, look up the part for a 96 and see if the pic matches whats on your vehicle Link to comment Share on other sites More sharing options...
RedGTLegacy Posted March 14, 2014 Author Share Posted March 14, 2014 Thanks! I appreciate it, hopefully have this resolved sooner than later! Link to comment Share on other sites More sharing options...
