I have a 97 legacy gt wagon. I have the front half of a 4 inch sjr lift. I can not at this time afford to purchase the rear half. but I have access to all the equipment needed to fab the rear myself. my question is do you have to adjust angle of the REAR STRUT MOUNTS like the angle of the front strut lift mounts are, or are they just straight(square). thank you all for the info in advance.
@gloyale
the 10* you add into a 4 inch lift, is that 10 towards front,rear,inboard or outboard. i appreciate your help a ton. so, if i call the top of the mount 0* which direction should the angle go? thanks again, nathan
