CMJAnew Posted March 15, 2014 Share Posted March 15, 2014 Finally purchased a volt meter (extremely cheap one) to get to the bottom of the not charging issue. Tested the battery with engine NOT running = 13V (I had charged it fully a couple weeks ago) Tested the battery with engine at idling = 12V Tested the battery with engine under load = 12V to 13V Never went above 13V Do you all think I should go straight to replacing the alternator? Link to comment Share on other sites More sharing options...
CMJAnew Posted March 30, 2014 Author Share Posted March 30, 2014 (edited) After getting some suggestions on a Brat/Brumby facebook page I took the instrument panel out (it was suggested a burned out "charge" light would not allow the alternator to function correctly). THERE WAS NO LIGHT AT ALL. So I switched one from the "oil" to "charge". This made no difference -- still no charge. So, I did what any normal guy would do ---- Replaced the alternator with a fresh rebuilt. NOW IT CHARGES. I was going to let it idle a while to be sure but, alas, blew the lower radiator hose. __________________________________________________________________________________________________________________ As to the instrument panel lights -- they ALL seem to be on ALL the time now. Any ideas why? And, what to do 'bout it? Plus, any ideas where to get the smaller of the lights and sockets for the instrument panel? The larger (1/2") ones are readily available on eBay. Edited March 30, 2014 by CMJAnew Link to comment Share on other sites More sharing options...
ivans imports Posted March 30, 2014 Share Posted March 30, 2014 On mine the brushes wore down and were not contacting well was really easy to change them Link to comment Share on other sites More sharing options...
