Speedwagon Posted March 15, 2014 Share Posted March 15, 2014 Among the numerous things I am fixing on the Brat, one of them is the windshield gasket. It leaks, at every corner. Just got the windshield out, and there is old adhesive in certain spots and some rust in spots. Does a new rubber gasket require any silicone/adhesive to be used at all? And is my best bet to wire brush the rust away, and hit it with some of the rust-to-primer stuff before putting the windshield back in? Link to comment Share on other sites More sharing options...
the sucker king Posted March 16, 2014 Share Posted March 16, 2014 (edited) ....... Edited March 18, 2014 by the sucker king Link to comment Share on other sites More sharing options...
the sucker king Posted March 16, 2014 Share Posted March 16, 2014 If you do happen to find the gasket without the groove in it, PLEASE let me know, I would like to pick one up. If you need help finding the other gasket, let me know, I still have my receipt. Link to comment Share on other sites More sharing options...
Speedwagon Posted March 16, 2014 Author Share Posted March 16, 2014 I managed to find the gasket on Rockauto when I was looking for the heater core. $67 I think? And thanks. Link to comment Share on other sites More sharing options...
jonas Posted March 16, 2014 Share Posted March 16, 2014 Maybe you could do a write-up on this? I've seen it done several times (I think I've busted the front glass on almost every car I've owned) and fairly confident in my ability to do it, but would like to make sure I'm getting all the steps correct. I need to replace the front glass in my wagon. Well, don't NEED to, but I do have a small crack in it and a replacement for it sitting in my shed. Link to comment Share on other sites More sharing options...
skishop69 Posted March 17, 2014 Share Posted March 17, 2014 Actually, there is a sealant that is used with these gaskets. It is not a silicone. It is a non hardening, very tacky substance similar to butyl tape but much more pliable. Ask a windshield shop and they'll know the name. It escapes me at the moment. You need to use this if you don't want leaks and you can still remove it if necessary. Somewhere her, there is a brief write up I did in another post when someone was asking what to use and how to install, but I don't have time to look right now. You'll need to prime and paint any rust spots prior to install or they'll just get worse and end up leaking. Link to comment Share on other sites More sharing options...
the sucker king Posted March 18, 2014 Share Posted March 18, 2014 On 3/17/2014 at 2:49 PM, skishop69 said: Actually, there is a sealant that is used with these gaskets. It is not a silicone. It is a non hardening, very tacky substance similar to butyl tape but much more pliable. Ask a windshield shop and they'll know the name. It escapes me at the moment. You need to use this if you don't want leaks and you can still remove it if necessary. Somewhere her, there is a brief write up I did in another post when someone was asking what to use and how to install, but I don't have time to look right now. You'll need to prime and paint any rust spots prior to install or they'll just get worse and end up leaking. I have been told by multiple people that I trust that these gaskets are meant to be used with no sealant, glue, or goop of any kind. then you post this. So I check with a gen 2 Factory service manual. Why did I not do that before? dunno. It says to use starseal U-70 sealant, accompanied by this diagram for where you want it. I apologize for posting wrong info, and thanks for the coorection, I'll edit my prior post to remove wrong info. for the record, I did a gen 1 windsheild without sealant also based on the wrong info, It worked okay. Link to comment Share on other sites More sharing options...
the sucker king Posted March 18, 2014 Share Posted March 18, 2014 should add, I have no idea what starseal u-70 is. would seem to be a product of the past. Link to comment Share on other sites More sharing options...
Speedwagon Posted March 19, 2014 Author Share Posted March 19, 2014 (edited) Well, at least it seems to be something you add AFTER you install it. Which I just did. Not too bad, though not super easy either. I think I'll wait and see how it goes first. Edited March 19, 2014 by Speedwagon Link to comment Share on other sites More sharing options...
