help cutting tire....
Ok so after trying to cut a tire to make rubber bump strips for my push bar, my right arm is shredded and right hand looks like I tried karate chop a cactus.
The tin snips I am using are getting really dull and it's having a hard time cutting through the steel belts.
Anyone have any tips on making this easier? I do plan to wear gloves and a long sleeve shirt on my next attempt.
sawzall and steel blade cuts them like butter.
heck my pocket knife slashes tires, through belt mind you, like its mustard, ive done it a few times.
but good luck, and shawn has a good idea.
Later,
Shean
or go down the road and find a blown out tire, where it self destructed :brow:
That's where I got the tire from.
It's just a outer part of the tire left. No bead or sidewall.
Will try the sawzall idea. I think I will mount the tire to a piece wood to make it easier to work with. If that fails will go to the re-tread place.
Thanks for the input
