jeffroid Posted March 19, 2014 Share Posted March 19, 2014 I have a 1996 Legacy Outback 2.2 Liter with manual transmission. I was in the middle of my commute in cruise control. The traffic ahead slowed and right as I took it out of cruise control to decelerate, I noticedout of the corner of my eye that the speedometer needle went straight to zeroand stayed there. Otherwise, nothing unusual occurred and there were no symptoms whatsoever. After a few minutes, the check engine light came on. After I got home, I plugged in a code reader at the auto parts store and the codeas described in the topic title appeared. I cleared the code and drovehome. The speedometer still does not work, but the check engine light hasnot come back on again (only a few blocks). I'm guessing that I just need to buy the Vehicle Speed Sensor that screwsinto the transmission much like where you used to screw in your speedometercable in the olden days. I see them online for around 100 bucks. I searched but didn't readily see a similar issue or a direct answer to myquestion. So I figured I would check here first before spending a hard earned$100 without fixing the issue. Any help is greatly appreciated. Thanks. Link to comment Share on other sites More sharing options...
987687 Posted March 19, 2014 Share Posted March 19, 2014 http://www.ultimatesubaru.org/forum/topic/115677-p0500-repair/ The easy option is to hope that is your problem. Pulling the gauge out isn't a big deal. One does not simply replace the VSS.... They are a royal pain in the butt. It has terrible access, and it's plastic threaded into aluminum, with red loctite. Thanks subaru. Check wiring, the gauge and everything else before dealing with a vss replacement. The last one I did was during a rally service, and I ended up breaking it off, melting it with a torch and picking it out in pieces... But I had a half hour time constraint... The one you have pictured is a two wire, 96 will be a three wire, but yes. That's the vss. Link to comment Share on other sites More sharing options...
jeffroid Posted March 19, 2014 Author Share Posted March 19, 2014 Thank you for the response. My vss is two wire. I read up on it some more. First I unhooked the electrical connector, then hooked up some speaker wire to the connector and ran it through the window so that I could read the voltage as I was driving down the road with a multi-meter. With the meter set on AC, it wasn't reading any significant voltage. So then I removed the vss from the transmission. It wasn't that hard to get out as it had recently been removed and reinstalled when I swapped transmissions. I hooked it up to a drill motor and it again was not reading any significant voltage with the multi-meter set on AC. That pretty much proves I have a bad vehicle Speed Sensor, correct? Link to comment Share on other sites More sharing options...
