Question on 3rd gen/Loyale windshields
The windshield glass on the 3rd gen bodies is glued on, and the rubber surround is just trim, correct?
I'm asking because while working on my 'rain came through the fresh air inlet' problem, I discovered that the
Safelite crew who replaced my cracked glass two years ago were a bit sloppy with the urethane, and had
managed to get some under and on the top edges of the plastic cowl pieces in spots. After removing the cowls,
I have two short spots where that rubber surround is lifted out of the channel between the body and glass. If it's just
trim, I should be good; if it's the actual seal, I'm screwed?
Edited by SmashedGlass
